Fuel sending units
Cougarholic
Fuhrpark: 1968 Cougar Xr7
Likes vergeben: 324 x
Likes erhalten: 33 x
Fuel sending units
Beitrag von Cougarholic » 21. Mär 2026, 11:49
Bill Basore
What you need to know about sending units.
All Ford Gauges, for fuel oil pressure and temperature are the same internally. They are grounded through the sender. Period. No other grounds are involved.
They are all fed by the Instrument voltage regulator. The factory unit puts out pulses of 12 volts that average out to 5 volts of continuous power. You cannot test these unless you have an oscilloscope or a meter with the capability to average over a very long period of time ($$$$$) The solid state after market IVRs typically put out 5 volts continuously. You can measure output from these. Both styles MUST be grounded through the case to the car.
All senders are variable resistors. The ones for oil pressure and fuel level use a sweep arm that moves over a wire wound resistor. The temp sender uses a negative temperature coefficient thermistor. That means resistance goes down, when temp goes up.
Shorting or grounding the sender wire is a good way to damage a gauge. DO NOT leave it grounded for long. If you see all the gauges pegged on maximum do not operate the car. The gauges are going to get fried. This is almost always an indication that the IVR has failed.
Gauges read according to resistance.
73 ohms bottom of scale.
60 ohms =0
35 ohms =1/8
28 ohms =1/4
23 ohms =1/2
15 ohms =3/4
10 ohms = 1/1
Notice that the scale is not linear. Resistance values has a plus of minus variance to so the bigger the number, the bigger the range of values that is still considered correct. That is why calibration occurs at the top of the scale.
Many aftermarket senders use a linear resistor. It can be accurate at empty and full and be wildly off everywhere else. For example when the gauge shows 1/2 you really have 3/4 tank. When you see 1/8 of tank you really have 1/2.
60 ohms =0
54 ohms =1/8
48 ohms =1/4
35 ohms = 1/2
23 ohms = 3/4
10 ohms =1
Finally you have a fuel level gauge. It doesn't measure gallons. If you put in two gallons it will barely move the needle. It is showing you the level of the accessible gas in the tank. The fuel pick up is not able to, or designed to, access the last drop.
If you have read this far you should probably copy this or share it with other Ford groups or what ever. This is not a guess. I rebuild senders professionally and I have the Ford gauge testers and literature.
