Zink (ZnO) vs MoS2
FullSizeFrank
Fuhrpark: 6 x FoMoCo
Likes vergeben: 86 x
Likes erhalten: 174 x
Zink (ZnO) vs MoS2
Beitrag von FullSizeFrank » 29. Nov 2024, 10:33
Hier ein interessantes Experiment zu den beiden Öl-Additiven
https://pmc.ncbi.nlm.nih.gov/articles/PMC7118172/
2 legit 2 quit
Likes erhalten: 1279 x
Beitrag von Schraubaer » 29. Nov 2024, 11:51
Es lebe das Zink! :mrgreen:
FullSizeFrank
Beitrag von FullSizeFrank » 29. Nov 2024, 12:22
Und das MoS2! Ab der richtigen Dosis ziemlich schnuppe
Adding ZnO and MoS2 nanoparticles to pure oils at different concentrations increased the flash point of the nano lubricants relative to the pure diesel oil. Compared to the pure diesel oil, the flash point of ZnO and MoS2 nano lubricants at 0.7 wt.% of each of the nanoparticles increased by 5.88% and 5.04%, respectively.
The pure diesel oil containing ZnO and MoS2 nanoparticles showed better anti-friction and anti-wear features as compared with the pure lubricant. The optimum concentration for ZnO and MoS2 nanoparticles was 0.4 wt.% and 0.7 wt.%, respectively. Friction coefficient at optimal concentrations from each of the ZnO and MoS2 nano lubricants decreased by 5.86% and 12.29%, respectively. Also, the results of the mass loss of the pins indicated better anti-wear performance of MoS2 nanoparticles than ZnO nanoparticles.
2 legit 2 quit
FullSizeFrank
Beitrag von FullSizeFrank » 29. Nov 2024, 12:35
Im Gegensatz zu Zink ist dann MoS2 in höherer Menge nicht so schädlich ...
2 legit 2 quit
Beitrag von Schraubaer » 29. Nov 2024, 12:51
the addition of ZnO nanoparticles with pure oil lubricant is more suitable than MoS2 nanoparticles for improving the thermophysical properties of pure oil.
FullSizeFrank
Beitrag von FullSizeFrank » 29. Nov 2024, 13:04
Einfach irgendwas rauskopieren ist leicht, kann ich auch ;)
In nutshell, MoS2 nanoparticles had more excellent anti-friction and anti-wear characteristics in comparison with ZnO nanoparticles
2 legit 2 quit
Beitrag von Schraubaer » 29. Nov 2024, 15:11
Es leben die Wiedersprüche!
Da ich zuerst kopiert habe, ist DAS richtig! 😜 Wer zuerst kommt malt zuerst! :mrgreen:
Ist auch 💩egal was drin steckt, bei den meisten Fahrweisen und Wechselintervallen kommt das eh' kaum zum Tragen.
FullSizeFrank
Beitrag von FullSizeFrank » 29. Nov 2024, 15:28
Da geb ich Dir recht :D
So oder so, es lässt sich mit Zusätzen im Motoröl einfach viel besser schlafen
2 legit 2 quit
FullSizeFrank
Beitrag von FullSizeFrank » 29. Nov 2024, 16:30
https://www.liqui-moly.com/de/de/oil-ad ... tion-title
Das kipp ich seit 21 Jahren, bei jedem Ölwechsel, mit rein.
2 legit 2 quit
Beitrag von Schraubaer » 29. Nov 2024, 16:40
images (4).jpeg (15.39 KiB) 6535 mal betrachtet
